My Jimmy will start, run for about three minutes, then after idling from aboutv1200 rpm until warms to idle at 750 rpms, the engine shuts off.
1992 GMC S 15 Jimmy 4×4
Keywords:Jimmy
Does it start right back up?
Possible IAC – Idle Air Control
Possible vacuum leak
Is the check engine light on – Check Codes Yourself Here
Will it stay running if you give it a little gas? Clean the throttle body
