Sep 272015
No brake lights or turn signals in rear. Bulbs and fuses good. Taillights and third brake light work
  One Response to “2006 Ford Focus ZX3”
  1. The common part is the GEM Generic Electronic Module. The GEM uses Fuse #32. The third brake light does not go through this module but the rear brake lights and turn signals do. So the wiring going to or coming from or the module itself. They also share the same ground connection so test and rule that out first.
    How to test with a multi-meter
 Leave a Reply
