while driving my 2007 Automatic Transmission Mazda 6 sport gt on the highway and i accelerate abruptly the rpm is getting to a high number like 7000 but the car isn’t accelerating,it feels like i am driving a manual transmission car and i stepped on the clutch all the way and accelerated.What do you think is the problem and how it should be fixed?
Transmission problem. May be electrical or mechanical. Would require an inspection and possible computer diagnostics.
Is it possible that it is the gear slipping?
Gears don’t slip. The internal clutches do, but I know what you mean. Yes it is possible. There would be signs of failure that would be visible by looking at the transmission fluid. If the fluid was dark and smelled burnt…. the clutches are worn(and would cause the gear slippage). If the fluid looked fresh, clean and new… it would be an electrical problem.
Thank you very much .I appreciate it very much:):)
Your Welcome.
Is it possible to diagnose if the problem is electrical or mechanical by myself?
And I changed the battery recently ,does it have any effects on the gears in any way possible??
You would need to have a Diagnostic Scan Tool
