chevrolet colorado 2010
repair terminal to battery
Chevy Colorado
4 thoughts on “chevrolet colorado 2010”
  1. If it is corroded, just pour boiling hot water over it and it will remove the corrosion enough to be able to remove the battery cable end. If it needs to be replaced make sure the cable is long enough to install an aftermarket terminal end. If it falls short, you will need to replace the entire cable.
    replace battery terminal end
  2. 2012 Chevy Colorado 2.9 l engine vortec engine p0017 code I have replaced crankshaft sensor camshaft position sensor and a variable valve timing sensor p0017 code still comes on could you help i
