My ex is a mechanic and a felon he had my truck and I had to get the cops to get it back. Now my transmission is screwed up!!! What do you think he did. There’s the right amount of fluid but the throttle is erratic.
The throttle would be more of an engine issue and have nothing to do with the transmission. If he engine was revving and the truck wouldn’t hardly go, then that would be a transmission issue. An erratic throttle could be form need of a tune up, bad gas, failing TPS Sensor that is built into the throttle body. If the check engine light is on, stop by just about any auto parts store and they will pull the codes for free. Post any codes below.
