flooding out can’t accelerate.
I’ve changed the EGR valve, PCV ell’s on tube, and o-rings on fuel injectors and now it wont crank at all.
I am guessing the reason it won’t turn over is from running the battery dead trying to start it and leaving the hood up. Recharge the battery.
I would thing if it is flooding out this bad that maybe one of the fuel injectors is stuck open. Probably wouldn’t set any kind of a code either. Remove all the spark plugs and have someone cycle the ignition key several times and you should see fuel in one of the spark plug holes. Replace that injector.
