Home » Car Questions » 2006 Dodge stratus
2006 Dodge stratus
2006-dodge-stratus
My Stratus is missing, the code is P0302 misfire on cylinder 2, I replaced plugs, wires, fuel injector and a coil pack. I also put a new cam shaft and crank shaft sensor on it and it still misses. Its not using oil or smoking
2 thoughts on “2006 Dodge stratus”
  1. P0302 Dodge – Cylinder Misfire Fault Detected
    Possible causes
    – Faulty spark plug 2
    – Clogged or faulty fuel injector 2
    – Faulty ignition coil 2
    – Fuel injector 2 harness is open or shorted
    – Fuel injector 2 circuit poor electrical connection
    – Ignition coil 2 harness is open or shorted
    – Ignition coil 2 circuit poor electrical connection
    – Insufficient cylinder 2 compression
    – Incorrect fuel pressure
    – Intake air leak
    The P0302 code means that the cylinder 2 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 2. If the problem persist more tests needs to be done to diagnose problem, see “Possible Causes” When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Crankshaft Position (CKP) sensor signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
