When am driving my stiring wheel very hard to turn and if i accelerate a little when am turning the stiring wheel softens why
Three reasons for this come to mind.
1) Over-sized tires or aggressive tread design (All-Terrain) :
– The power steering pump is unable to provided enough pressure to make up for the extra tire grip
2) Power steering pump going out :
– If the power steering pump is leaking or the pump is worn and no longer producing normal hydraulic pressure
3) Worn steering components :
– If some or any of the steering components are binding it would make it difficult to turn
4) Loose power steering pump belt :
– If the belt is loose the pump may not be able turn as it should
Accelerating the engine increases the power steering pump speed which in turn increases the pump pressure.
