Home » Car Questions » 2002 Ford Windstar
2002 Ford Windstar
2003 Ford WindstarMy van is currently having issues. First it has been dying during idle not immediately but soon after it has to idle for a minute. The check engine light is on and the codes come out to lean combustion (autozone). When I push on the gas to get up to speed after idle the CEL starts to blink and the van doesn’t seem to be getting enough gas. Sometimes I smell exhaust and sometimes a puff of white smoke come out of the exhaust on starting it. If I’m stopped at a red light it kinda chugs but if I put it in neutral it seems to run a little better. The rpms drop during idle also. If you have a good Idea of what’s going on, it would be much appreciated
White smoke from the exhaust is an indication of a blown head gasket. This would also cause a rough idle and could cause the engine to want to die. Check coolant level and cylinder compression.
System Too Lean Possible causes
– Intake air leaks
– Faulty front heated oxygen sensor
– Ignition misfiring
– Faulty fuel injectors
– Exhaust gas leaks
– Incorrect fuel pressure
– Lack of fuel
– Faulty Mass Air Flow (MAF) sensor
– Incorrect Positive Crankcase Ventilation (PCV) hose connection
