2002 Mercedes C230 won’t shift
2002 Mercedes C2302002 Mercedes C230 won’t shift to reverse or park, stuck in neutral and drive.
My best guess would be a damaged shift cable. Disconnect the cable from the shifter and see if it moves. If not the shifter itself is damaged. If it moves, reconnect the cable to the shifter and disconnect the other end. If it does not move, the cable is damaged. If it does move, internal transmission issue.
