Transmission Solenoid Estimate 1998 Chevy Blazer
1998 Chevy BlazerI need a transmission solenoid estimate. How much with parts and labor should changing 2 solenoids cost in transmission? Also, if you change 2, how likely is it that others might fail?
Shift solenoids are around $20 each on amazon with the torque converter clutch solenoid around $30. They also offer a 5 Solenoid piece kit under $100. Just depends what direction you want to go. And lastly you are going to need some transmission fluid and a new filter and gasket. About 6 quarts of transmission fluid at around $3. A Transmission filter and gasket kit around $30.
Now we know a shop is going to charge a mark up on the parts and may also want a diagnostic fee and some extra shop supply fees.
  • Total Parts + 50% markup = $225
  • Total Labor @$100 per hour(shop rate) = $225
  • Diagnostic fee = $75
  • Shop supplies(rags, cleaners, etc) = $25
  • Tax @7% = $38.50
Total Cost Estimate for 2 solenoids = $588.50 (low end estimate, dealership may charge more)
Total Cost Estimate for 5 solenoids = $765.05
50/50 chance of failure with other solenoids.
Labor time would be about 2 hours for replacing one solenoid. Add an additional 15 minutes for each additional transmission solenoid.
Converter Clutch Solenoid Assembly, Replace (b)
Labor Times
Comments Factory Regular Severe
1.4 1.9 2.2
Addons
w/skid plate add 0.0 0.3 0.3
