Code P0510 Holden Barina xc 2002
2002 Holden BarinaCar runs fine but throttle body open and closes once when car switched off.
As long as the car runs fine I don’t think you need to worry to much about it. If the check engine light is on, the diagnostic trouble codes should be pulled.
Code P0510 – Closed Throttle Position Switch Malfunction
The throttle body or linkage on certain vehicles may contain a switch. It indicates to the Powertrain Control Module (PCM) or Engine Control Module (ECM) when the throttle body is in the closed position. When the throttle body is shut, the switch will be depressed or in the closed position. The PCM uses this switch so the engine will stay at idle in conjunction with the idle air control valve and/or go into a fuel cut mode while coasting.
There may also be a Wide Open Throttle (WOT) switch. If either the WOT or closed throttle switch are not engaged, the PCM or ECM may assume the throttle is partly open which could affect the air/fuel ratio.
Note: If more than one trouble code is present, such as P0120 (TPS/Pedal Position Sensor A circuit Malfunction) – there may be an open in the ground circuit or bad connection at the Throttle Position Sensor TPS).
Code P0510 Possible Solutions
Wiring Harness
Disconnect wiring harness connector at Throttle Position Sensor (TPS) or closed throttle position switch and harness connector at PCM/ECM. Using a Digital Volt Ohm Meter (DVOM) set to ohms scale, connect leads to each end of the same wire using a wiring diagram for reference to test for continuity between the switch and the PCM/ECM. Resistance should be present in the wiring between the switch and PCM/ECM, an infinite reading would indicate an open circuit. Repair open in wiring or replace wire harness assembly.
Disconnect wiring harness connector at TPS or closed throttle position switch and test for continuity using the DVOM with the leads on the two pins at the closed throttle position switch or the throttle position sensor, depending on the vehicle. Resistance should be present when the throttle body is in the closed position. If the throttle body linkage is not touching or fully closing switch, there may have been an adjustment made to the idle set screw. Re-adjust idle set screw to specifications using factory procedure.
