Ignition Module 1993 Ford Ranger XLT 4×4 3.0L
1993 Ford RangerI’m currently having a problem with my Ranger choking out or stalling right after it starts. It will run intermittently from time to time but only for a few minutes. I have replaced the fuel pump, fuel filter, flushed the tank, replaced cap, rotor, plugs, wires, air filter, removed catalytic converter, checked for vacuum leaks, cleaned throttle body, and basically at a loss.
Ignition Module
I have found that the most common cause for this would be a faulty ignition control module.
The part is less than $50 and can be sent to the house.
Replace Ignition Control Module 3.0L engine
1. Disconnect the negative battery cable.
2. Remove the distributor assembly from the engine.
3. Place the distributor on the workbench and remove the module retaining screws. Pull the right side of the module down the distributor mounting flange and back up to disengage the module terminal from the connector in the distributor base. The module may be pulled toward the flange and away from the distributor.
NOTE: Do not attempt to lift the module from the mounting surface, except as explained above. The pins will break at the distributor module connector.
To install:
4.Coat the base plate of the TFI ignition module uniformly with 1 ⁄ 32 inch of silicone dielectric compound WA–10 or equivalent.
5.Position the module on the distributor base mounting flange. Carefully position the module toward the distributor bowl and engage the three connector pins securely.
6.Install the retaining screws. Tighten to 15–35 inch lbs (1.7–4.0 Nm), starting with the upper right screw.
7.Install the distributor into the engine. Install the cap and wires.
8.Reconnect the negative battery cable.
9.Recheck the initial timing. Adjust if necessary.
If the check engine light is on you can pull the engine trouble codes without a scan tool.
