Hi, I have a Seat Ibiza 1.9tdi pd130 2002 the car hardly turns over sounds like batteries dead/dying but has plenty of life, the RAC suggested was starter motor got that replaced and still the same, jump start doesn’t work but bump starts no problem, and noticed to day that fan in car cut off for a second quite few times, any suggestions.
Hardly turns over
Sounds like a bad cell in the battery. Replacing the battery should take care of this issue. A load tester would be needed to make sure but even then the test is not 100% all the time. If the battery is even close to being 4 years old it is reason enough to go ahead and replace it.
