Hi, my car won’t move in drive
Car won’t move in drive
First thing to check would be the transmission fluid level. If it is low, top it off and test. If it is not low, look at the color against a white paper towel. If the color looks dark or burnt then there may be internal damage. If the fluid level is full and the color is pretty pink, there may be a sticking solenoid in the transmission.
Of course there may be other things that could cause this such as a broken cv axle shaft but that isn’t very common. Another cause could be the shifter isn’t going into gear all the way. Try moving the the shifter to low and see if it will do anything. Does it move in reverse?
My car doesn’t move in drive, but it does in L1, L2, and reverse.
The transmission fluid level is ok, but it is a tan/light brown colour. Not burnt and doesn’t smell burnt. Thanks.
Then most likely you have a sticking shift solenoid or a faulty gear selector switch.
A transmission shop should be able to hook up a scan tool and determine the issue from any present codes.
