I have a 2010 steed 5, 2.8 Tci bakkie and after reconditioning the engine it cranks but won’t start. I can start and run it using quick start but the moment I stop spraying the quick start it cut off, injectors is on the original cylinder, it just seem that the injectors are not letting fuel in. If someone had encountered this problem before please contact me via email XXX.XXXXXXX@XXXXXX.XXX
Since you have had this apart, I would start by checking for loose connections or things that are not plugged in correctly. Usually a check engine light will illuminate and help guide you in the right direction. If you have any codes present feel free to post them below.
Checked everything is good, just heard that the injectors on the GWM has to be reprogrammed so I’ll have that done, I only get one error on my obd11 scanner and that says glow plug bank B, even though I replaced the two that was not working, I’m still getting that error.
It would be helpful if you could post the actual code.
