Low beam bulb went out again 2006 Nissan Altima 2.4l engine
Nissan Altima
A month ago my low beam bulb(right side) went out, I changed it, everything worked perfect. Here i am a month later ,replacing it once again, except this time the new bulb isn’t coming on.
What could be causing this?
Left side works perfectly fine.
You can swap the left side (good) bulb to the right in order to test if it is the socket. Alternatively you can in stall the newly purchased bulb into the left side to see if the New bulb is bad. It happens.
In most cases the issue is caused from moisture getting into the headlight assembly either from damage or age.
How to replace the headlight on 2006 Nissan Altima
2006 Nissan Altima Headlight Bulb Replacement
