You gave me the labor time to replace the valve spring on my Enclave and I was shocked to see it was only 7.9 hours. My question is can you tell me what special tools are needed? Also do you know what all is required to be removed to do this I have already pulled the intake and valve cover but I thought it would need the timing chain removed so the cam can be pulled to do the spring but I cant imagine all that is done in just 7.9 hours so I am trying to figure out how this is done?
To be clear the Labor time to remove and replace the valve springs is 7.9 hours for the right bank only. It is 12.3 for both banks.
For full instructions that include images and diagrams Select your vehicle specific Auto Repair Manual Here.
Valve Spring Replacement – Right Side
Special Tools
- EN 46106 Flywheel Holding Tool
- EN 46110 On-Vehicle Valve Spring Compressor
- EN 46116 Valve Stem Seal Remover/Installer
- J 39313 Spark Plug Port Adapter
Removal Procedure
- Remove the starter motor.
NOTE Important
If the EN 46106 flywheel holding tool is not installed, the crankshaft may rotate. If the crankshaft rotates, disassembly and reassembly of the entire camshaft timing system may be required.
Install the EN 46106 flywheel holding tool in order to prevent crankshaft rotation.
- Remove the camshafts and rocker arms.
- Remove the spark plug from the applicable cylinder.
- Install the J 39313 spark plug port adapter to the applicable cylinder.
- Connect the J 39313 spark plug port adapter to a compressed air source.
Install the EN 46110 on-vehicle valve spring compressor above the applicable cylinder as shown.
- Tighten the EN 46110 on-vehicle valve spring compressor valve spring compressor nut (2).
Remove valve keepers Remove the valve keepers.
- Loosen the EN 46110 on-vehicle valve spring compressor valve spring compressor nut.
- Remove the valve spring retainer.
Remove the valve springs.
Use the EN 46116 valve stem seal remover/installer (1) in order to remove the valve stem seal (2).
Installation Procedure
Use the EN 46116 valve stem seal remover/installer (1) in order to install the valve stem seals (2).
Install the valve spring.
- Install the valve spring retainer.
Install the EN 46110 on-vehicle valve spring compressor above the applicable valve spring as shown.
Install the valve spring keepers.
- Remove the EN 46110 on-vehicle valve spring compressor .
- Disconnect the J 39313 spark plug port adapter from the compressed air source.
- Remove the J 39313 spark plug port adapter .
- Install the spark plugs.
- Install the rocker arms and camshafts.
- Remove the EN 46106 flywheel holding tool .
- Install the starter motor.
