Hello. I’am Fred. My turn signal will not turn off when I turn my steering wheel an my wiper blades don’t work together now. I have put in a new turn signal lever an a new clock spring. Please tell me what is wrong with this van.
The most common cause for this issue falls on a faulty multi-function switch. This switch receives a lot of use and therefore tends to wear out quickly. Here is the exact fit part required for replacement.
Multi-Function Switch Replacement
REMOVAL
- Disconnect and isolate battery negative cable.
- Remove upper and lower steering column shrouds.
- Disconnect wire connector from back of multi-function switch.
- Remove screws holding multi-function switch to steering column adapter collar.
- Remove the multi-function switch.
INSTALLATION
- Position the switch on to the steering column.
- Install the two retaining screws.
- Connect the wire harness connector.
- Install the upper and lower steering column shrouds.
- Connect the battery negative cable.
