The van just had a new starter and battery put in; the starter clicks when I turn the key sounds like its going to engage then when I try to turn the key again it doesn’t do anything what could be the problem?
When you turn the key to the “start” position do you get one click “CLICK” or do you get repeating clicks ” CLICK,CLICK,CLICK, etc” ?
1)Repeating clicks is an indication of a dead battery
2)One Hard Click is an indication of a loose connection or failing starter
If the battery is dead, test the alternator to make sure it is charging.
