Normally when the car is turned off the radio will stay on until you open the door. Now the radio and the clock in the dash will never turn off. The door switch is good. Any ideas?
In most cases the door switch/latch assembly is the problem. If you are certain the switch is good, then obtain a wiring diagram and start tracing the wires with a multi-meter.
http://www.freeautomechanic.com/wiringproblems%206.html
