I have VX V6 with what appears to be a leaking core plug between the transmission and motor. How many core plugs are there and what sealant is best recommended when fitting new core plugs? Also need to find out torque settings on flywheel bolts and if loctite is necessary on these bolts. Any advice is good. Nothing worse than having to do a job twice. Look forward to hearing back!!
should be only 2 plugs on the back of the engine. I used loc-tite as a sealant for these plugs. Not sure what the toque specs are for this european car as I only have access to US vehicle specs, but No loc-tite is needed on these bolts.
