How to Remove the CaliperMay 13, 2010May 14, 2010How do you remove the brake-caliper guide pins on a 1990 Ford Ranger 2.9L?Keywords:brake caliperBrakesford ranger1 thought on “How to Remove the Caliper” Jaxer May 14, 2010 at 12:02 pm You take a Flat screw driver and hit on the outer edge of the guide pins so they move just under the retaining lip. Do this on top and bottom of the guide until it is pinched inside and knock it the rest of the way out.Comments are closed.previous’81 cutless supreme v6 3.8LnextI need help.
