Home » Car Questions » 2000 Ford Contour sport 2.5l v6
The brake light will not turn off. put in new alternator and fuses. Why will the light not go off?
2 thoughts on “2000 Ford Contour sport 2.5l v6”
  1. 2000 Ford Contour Sport 2.5l v6 the battery light will not go off? Why is this? Put in new alternator and fueses
  2. The Brake light Switch that is mounted on the brake pedal is probably at fault. Replacing the sticking switch should cure this issue. < answer to first question.>answer to comment>
    The battery light is on becuase it is not seeing an adequit amount of charge. This can be cause by a bad alternator, bad ground, bad battery(shorted, not just weak) or a short in the system.
    Use a multi-meter and check to see if it is charging.
    http://www.freeautomechanic.com/wiringproblems%206.html
