My car (2000 Mitsubishi Magna Sports 3.5L dual trans) is making a knocking sound only when the engine is warmed up on the right hand side and when i get to 110Km’s the front of the car and steering wheel start vibrating and shaking heavily only when my foot is on the acclelarator. Foot off it stops, foot on over 110kms it starts. Mechanics diagnoses so far: Brisbane Mechanic -its your suspension $900, Pedders – suspension is 100% its your drive shaft and power steering rack $1500 Car Drives Brisbane to Melbourne. Ultra Tune -your drive shaft and rack are fine its your engine mount -$200- 2 hours later -your engine mount is fine its your transmission and unsafe to drive-$2800. Transmission place- transmission is 100% nothing wrong with it. Drove the car to Adelaide and car is still running but still knocking and vibrating.
Knocking and Vibrating
Does the knocking noise happen when setting still in park? If yes, You can remove the Serpentine belt and start the engine to determine if it is internal in the engine or external(water pump, alternator, a/c compressor, etc).
Put the car on jack stands to allow the wheels to move and have someone run the engine in gear at 110kms and look at the front end for movement in drive-train/suspension area.
