My motorhome turns over but will not start. i have installed a new battery and also have checked the fuel pum and fuel filter. i also checked to see if ther was spark from the distributor cap and there was. what am i missing?
1974 dodge Jayco motorhome
Keywords:No Start
http://www.freeautomechanic.com/nostart.html
Check for spark at the spark plugs and for fuel. If you have spark, you can try some starting fluid. If it starts and runs on the starting fluid then you know it is fuel related.
If you do not have spark, check the distriubutor cap and rotor(distributor)
