Heater Blower Motor High Speed and AC compressor not working. Would this be the fuse located beside the battery (HVAC). Normally I would just replace the fuse but I have noticed a strange behaviour when turning the blower control to high. The interior lights get really bright for a second and if I do it two or three times the ABS light and the Engine light will come on. I have tried to find a wiring diagram for the circuit but was unable to obtain one. I am worried that there is a major electrical fault here.
96 Olds Achieva
To fix the blower motor issue you will need to replace the Blower Motor Resistor. As for the Air Conditioning, you will need to troubleshoot the issue… most likely just low on Freon.
