I just had a fuel pump put on and now when i try to start it , it sounds like it is pulling the battery down and then it starts up. The battery bolts is tight,lights are not dim and i didn’t have this problem until i had the pump put on it can someone please help!
I don’t think the fuel pump repair has anything to do with this problem and think it is just a coincidence. Most likely the battery itself is failing and will need to be replaced.
