I have a 96 Jeep Cherokee sport. Straight six. It will not start. It will turn over and that’s it. We have replaced plugs, rotor, distributor cap. Fuel pump and filter. and the crank shaft sensor. When I look in the oil fill hole, it looks like the rocker arms are moving. I don’t think it is the timing belt. Help
1996 Jeep Cherokee Sport
First thing to do would be to see what it doesn’t have.
In order for an engine to run it needs 4 things.
1) Spark
2) Fuel
3) Compression
4) Timing
Once you have figured out what you are missing, then you can diagnose the problem.
helpful link: http://www.freeautomechanic.com/nostart.html
