Home » Car Questions » 2005 Mazda Tribute 2.3L 4cyl
Please help. I have tried everything….. okay so here is the problem, When ever i take it on the freeway over 55mph even for a minute when i exit it shakes and the rpms drop and it stalls sometimes.. drives fine in the city going under 55mph… This is what tried,
1 EGR VALVE
2MASS AIR FLOW SENSOR
3 THROTTLE BODY
4 idle control sensor
please help!
2 thoughts on “2005 Mazda Tribute 2.3L 4cyl”
  1. Sounds like the lock up torque converter is hanging up and not wanting to release after it has gone into overdrive and locked up. Most likely this will require the replacement of the transmission torque converter. I WOULD HAVE THE LOCAL TRANS SHOP CONFIRM THIS FOR YOU FIRST
