I just had my oil changed about 2 weeks ago. I don’t see any oil puddles under my car, but when I turn the car on it comes on, so I turn it off right away and then turn it back on and it goes off. Any ideas what the problem could be?
low oil light
It is normal for all dash lights, even the low oil light to illuminate when you first start the engine. The lights should then go off with in about 10 seconds.
If it is the change oil soon light, the oil change place may have just forgot to reset it.
To be on the safe side, I would check the engine oil level and make sure it is at the full mark. Check the oil level with the engine off and in park.
