The low beam headlight on the driverside is out and the high beam on the passenger side is out ive changed both bulbs but still not working what could be the problem is there a fuse that control them
No separate fuses, you may check the relays under the hood if you DRL but that shouldn’t cause this issue. You will need to use a multi-meter And check for power and ground at the socket itself and the wires going to them, you will need to repair the wiring or replace the socket if you do not have power and ground. If you do, then your bulbs are bad or not making good contact. double check and make sure your testing with the right bulb. There is a difference between a 3057 and a 3157 bulb.
