nissan micra k12 2003
failed emissions test on co,ie11.85vol%, low idle @ 800rpm.
lambda0.67, co 12.55 vol%. HC 593 ppm. @ 3000 rpm.
would Lambda sensor no 1 befaulted.
Thanks
1 thought on “nissan micra k12 2003”
  1. It is possible. You have a fairly major issue there, the exact problem would have to be diagnosed but I’d say you have a fairly major air/fuel ratio problem. Your lambda is 0.67, which means no air going in to system properly, so could be leaking air hose, dirty – never changed air filter or faulty air flow sensor.
