Short Answer: it should be under the dash near the steering column.
it has to be unbolted from engine side of firewall (bolts near brake booster) then you can pull it down far enough to unplug, and remove it.
More detailed Answer:
It is located on the driver’s side under the dash, to the left of the steering column, mounted to the firewall. It is not very big, maybe 2 inches square and one inch thick.
Disconnect the cable from the negative terminal of the battery.
Unplug the electrical connector.
Remove the module mounting screws and/or nuts (should be in the engine compartment).
Remove the module from the cowl panel.
Installation is the reverse of removal.
