1991 ford ranger xl 4×4
Major transmission leak around bell housing replaced front pump seal and same trans leak at bell housing whats wrong with it??
1 thought on “1991 ford ranger xl 4×4”
  1. I would look to answer the question of what caused the seal to go bad and leak to begin with. Most likely the front pump bearings are shot and there is no way it will seal while flopping around in there. Of course you would want to check for play before replacing the bearings.
    Another possibility could be the converter has a grove warn and would require a speedy sleeve for it to be able to seal.
