I just installed a new window regulator on front drivers side door. It worked find for about two days and now about 1/2 way up glass tilts forward and window gets stuck. Any suggestions on what I did wrong??
Sounds like something has come loose. You will need to retrace your steps and double check your work. Look for something that may have gotten in the way unintentionally. With the door panel removed it will be easier to examine what is going on when you test the window operation.
