mercedes 1992 300TE motor= 103
Need help instructions to remove oil pan (busted w/lg hole)
4 xmpl: when lift 2″ do I remove transmission support
and do I disengage header/exhaust pipe (2 ea.) ??
how about torsion bar…??
Tx
1 thought on “mercedes 1992 300TE motor= 103”
  1. Two ways to go about removing the oil pan.
    Leave the engine mounted and remove everything out of the way from underneath or un-mount the engine and lift it up high enough to remove the pan.
    If the exhaust is in the way, then you will need to remove it. Remove the transmission mounts to be able to move the assembly. Removal of the torsion bars should not be needed. Leave the transmission connected to the engine and just remove the oil pan.
