VEHICLE FALLS OUT OF GEER ON SHARP TURNS AND ABRUPT STOPS – WILL NOT GO INTO GEER WHEN TEMP IS UNDER 60 DEGREES WITHOUT EXTENSIVE WARM UP – HAVE TO RACE ENGINE FEW TIMES TO GET TO POP BACK INTO GEER – MAJOR PROBLEM?? EXPENSIVE TO FIX OR IS IT JUST SOMESORT OF SENSOR PROBLEM?
2004 chrysler sebring 4 cyl
First thing to do would be to check the fluid level of the transmission. This should be done with the engine running. Use a white paper towel and take note of the fluid color.
Fluid Level
1. Low – top off and test
2. Full
a. Dark in color – internal mechanical damage
b. Bright color – sensor/electrical issue
generally there is a code stored in the computer and can be pulled with a scan tool.
