Every time i get my car washed the left turn signal will not work when i put on the brake. when i release the brake the turn signal will work normally
2002 OLDS INTRIQUE
Keywords:Intrigue
Sounds like some unwanted water is getting inside the left light assembly. After you wash your car look to see if you see any moisture inside the front or rear light assembly. Replace the assembly if no cracks or seals are visible repairable.
Since the rear brake light bulbs and the turn signal bulbs are separate they only share a common ground, you may need to check the grounds and make sure they have a good clean connection.
