94 lexus es 300April 25, 2015my car doesnt move when i got it in drive when i.press gas the rpm goes up but the car.barely moves Keywords:ES300 1 thought on “94 lexus es 300” Freeautomechanic April 27, 2015 at 8:41 am First thing to check would be the automatic transmission fluid level. If it si low, it will not move. If it is full (with engine running) The you may have an internal shift solenoid problem with the transmission. How to check your fluid levels. Comments are closed.
