Home » Car Questions » ford econoline 250 2002
i get code 135 code 1131 and 1151 what it means
1 thought on “ford econoline 250 2002”
  1. P0135 – O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1
    The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem
    Possible causes
    – Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
    – Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
    – Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
    – Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
    – Faulty Engine Control Module (ECM)
    P1131 Ford – Lack of Upstream Heated Oxygen Sensor Switch Sensor Indicates Lean Bank 1
    Though the Oxygen (O2) sensor, the Engine Control Module (ECM) has detected a lean system, which means that there is either not enough fuel or and excessive amount of air in the system. Start by checking for vacuum leaks.
    Possible causes
    – Faulty Oxygen Sensor
    – Vacuum leak affecting bank 1 only
    – Fuel injector problem bank 1
    – Check for cylinder misfire on bank 1
    – Engine mechanical condition
    P1151 – Lack Of HO2S21 Switch – Sensor Indicates Lean
    Lack Of HO2S21 Switch – Sensor Indicates Lean is one of the definitions for the P1151; however your vehicle’s manufacturer may have a different definition for the P1151 code. Please check below for your specific make.
