Home » Car Questions » 2007 Dodge Charger Charger RT
I had to replace the condenser due to a hole from a rock. Now the dual temp control panel has no power. I have checked the fuses what do I do next
1 thought on “2007 Dodge Charger Charger RT”
  1. If your fuses to the temp control panel have power and the control panel does not, you will need to trace the wiring from the fuses to the control panel and repair as needed.
    If the fuses do not have power, you will need to repair the wiring before the fuse.
