I replaced the A/C compressor on my KIA Rondo, and it now cools well enough, but the compressor does not cycle on/off. I did replace the dessicant, but not the expansion valve. The engine light has been on for some time now, even before the compressor swap. The previous compressor froze up. What should I do?
If the AC is cooling well enough then I don’t understand problem?
Did you evacuate the system and draw a vacuum on the system before you added freon, if not… that is your problem.
Air Conditioning Troubleshooting
