If brake fluid is leaking into the brake booster do i replace the booster, the master cylinder or both.
2009 chev silerado 1500 V6
Keywords:silverado
The master cylinder is leaking, it will need to be replaced. Since brake fluid has gotten into the vacuum booster, I would recommend replacing it also.
