Home » Car Questions » 1986 Chevy cab forward control 7.4l engine
I have spark to the plug and I have gas in the carburetor, but the engine will not start. What is the next step? I have replaced the distributor cap, rotor, and fuel filter.
1 thought on “1986 Chevy cab forward control 7.4l engine”
  1. You need 4 things for an engine to run:
    1. Fuel
    2. Spark
    3. Compression
    4. Timing (the three above at the right time)
    A compression test and check your timing would be the next steps.
