P0017 Chevrolet – Crankshaft Position Camshaft Position Correlation Bank 1 Sensor ‘B’
Possible causes
– Dirty Oil
– Engine mechanical problems
– Faulty camshaft position sensor
– Faulty crankshaft position sensor
– Timing belt jumped P0300 Chevrolet – Cylinder Misfire Detected Random Cylinders
Possible causes
– Faulty spark plug (s)
– Faulty ignition coil (s)
– Intake air leak
– Incorrect fuel pressure P0506 Chevrolet – Idle Speed Control System RPM Lower Than Expected
Possible causes
– Dirty throttle body
– Electric throttle control actuator misadjusted or damaged
– Faulty Electric throttle control actuator
– Intake air leak P0315 – Crankshaft Position System Variation Not Learned
Possible causes
– Faulty Crankshaft Position (CKP)
– Crankshaft Position (CKP) sensor harness is open or shorted
– Crankshaft Position (CKP) sensor circuit poor electrical connection
– Damaged crankshaft pulse wheel teeth P1631 Chevrolet – Theft Deterrent Start Enable Signal Not Correct
Possible causes
– Dirty Oil
Possible causes
– Intake air leak
Possible causes
– Intake air leak
Possible causes
