I have spark to the plug and I have gas in the carburetor, but the engine will not start. What is the next step? I have replaced the distributor cap, rotor, and fuel filter.
1986 Chevy cab forward control 7.4l engine
You need 4 things for an engine to run:
1. Fuel
2. Spark
3. Compression
4. Timing (the three above at the right time)
A compression test and check your timing would be the next steps.
