It starts perfect cold, but once it warms up. it fails stating unless you give it some gas. The fuel pressure regulator is on the fuel pump on this car. If you suspect the fuel pressure regulator, how do you test it on the fuel pump?
2007 Buick LaCrosse CXS 3.6
I do not suspect the fuel pressure regulator. I suspect the IAC – Idle Air Control.
