Your question: “I was driving down the highway and all of a sudden when I gave it gas it started vibrating then the gas pedal stopped working and the motor died now it will turn over it just won’t start. What could cause this?”
2000 dodge durango
Keywords:Durango
Could be out of Gas. See if it will start by spraying starting fluid in the air filter.
You will need to determine if it is not getting fuel or spark. No fuel , you will need to determine if it has fuel pressure and injector pulse.
No spark, probably the Crankshaft Position Sensor
No Start Diagnostics
