2001 buick Le SabreSeptember 18, 2015Car won’t start. No fuel getting to engine. change relay change fuel filter and change fuel pump Keywords:Sebring 1 thought on “2001 buick Le Sabre” Freeautomechanic September 19, 2015 at 9:31 am What is the fuel pressure? Do the injectors fire? Does it have spark? If you spray starting fluid in does it try to start? No injector pulse and no spark = bad ECM fuse or Bad ECM. Does fuel pump come on? No Start Diagnostics Comments are closed.
